New LED facelift headlight - problem with blinkers and DRLs
  • Hello everyone,
    I’ve installed the new LED facelift headlights on my 2015 453. But I noticed two problems that I’m trying to solve in order to work as original.
    1) when low beam headlights are on and blinker is on (one or both), the DRL should completely turn off. Mine stays on.
    2) when low beam headlights are off
    - if one blinker is on, the DRL is turning off (so this is working on my car)
    - if both blinkers are on at the same time (hazard lights) the DRL should turn off (but DRL stays on in my car).
    So to sum it up, as soon as the blinkers are on, the DRLs should shut off and I can't apply it in all cases.
    (Blinker should be orange in all situations and not orange + white).
    I’m on SW15 version. Do you think the problem comes from wiring or coding?
    Thanks for your help.
  • davidoiknine
    Hat den Titel des Themas von „Nouvelle LED phare de levage - problème avec les clignotants et les problèmes de circulation“ zu „New LED facelift headlight - problem with blinkers and DRLs“ geändert.
