My car is Smart Prime 453.344, make year 07/2018, 66 kW Turbobenziner, factory-equipped LED and Sensor Package P25. The listed factory defaults below belong to my car.
You obviously changed quite a lot of EMM Edison settings. I like to understand why you changed them and what the reason or benefit was. With the new values, what exactly had changed in car operation?
The factory setting for Nbx_basic_PWM_adapt_DRL_Tail_CF is 0.15. For which specific reason did you set it to 0.22?
The factory setting for Nbx_TAIL_1_with_LED_CF, Nbx_TAIL_2_with_LED_CF, Nbx_TAIL_3_with_LED_CF is 0, 1, 0. For which specific reason did you set it to 1, 1, 1?
The factory setting for Nbx_DRL_with_LED_CF is 0. For which specific reason did you set it to 1?
The factory setting for Nbx_LowBeamwithoutPWM_CF is 0. For which specific reason did you set it to 1?
The factory setting for Nsx_Position_After_Stop_CF (sec) is 30. For which specific reason did you set it to 20?
The factory setting for Nsx_WGS_TM_CF is 30. For which specific reason did you set it to 12?
The factory setting for Nsx_welcome_period_step_CF (10ms) and Nsx_goodbye_period_step_CF (10ms) is 7. For which specific reason did you set it to 6?
The factory setting for Nsx_Wait_Goodbye_CF (sec) is 4.69. For which specific reason did you set it to 12?
The factory setting for Nbx_LED_Lowbeam_CF is 0. For which specific reason did you set it to 1?
Moreover, your flashers problem sounds to me a little bit like an electrical circuit overload problem. Maybe the flashers control unit gets too hot because it must deliver a lot of electrical current in hazard mode. And after a while it shuts down for temperature reasons. Try to temporarily remove/disconnect the right and left door flasher bulbs.
