Beiträge von RonnyFlex
    So, ich war heute nochmal am Fahrzeug mit der aktuellsten Datenbank die ich gefunden habe im Netz. Gescannt wurde mein Smart EQ MOPF.
    CAN scannen
    Identified ECU [ACC]@24 : Inverter_Emotor_SED_SW521_V2_20151110T155153.json DIAGVERSION [4]SUPPLIER [037] SOFT [0800] VERSION [0000] {5645}
    Identified ECU [BCM/UCH]@26 : T4_VS_BCM_BIS_DDT2000_SW15_x_VISTEON_SW18_x_CONTI_20200221T113530.xml DIAGVERSION [12]SUPPLIER [021] SOFT [0015] VERSION [0300] {18009}
    Found ECU [UPC-EMM] (no relevant ECU file found) :DIAGVERSION [0C] SUPPLIER [LEAR] SOFT [C50 ] VERSION [501 ]
    Identified ECU [CSHV Airbag Vehicle stopped]@28 : RSAT4_CSHV_eng_v2_5_20170519T094944.json DIAGVERSION [4]SUPPLIER [AMR] SOFT [0421] VERSION [0421] {405}
    Identified ECU [HVAC]@29 : ClimBoxGen2_v24_20171102T154632.json DIAGVERSION [4]SUPPLIER [740] SOFT [D602] VERSION [1707] {3199}
    Identified ECU [Airbag-SRS]@2C : ORC453_Optimize_03.00.07.ddt_20191209T164811.xml DIAGVERSION [29]SUPPLIER [AMR] SOFT [0600] VERSION [1926] {9590}
    Identified ECU [MIU]@59 : BIC_x07_S_S_v13_20200706T130237.xml DIAGVERSION [68]SUPPLIER [DX2] SOFT [0801] VERSION [0000] {16181}
    Identified ECU [Cluster/TDB]@51 : Cluster_X07ph2_EV_V1.2_20191220T142321.xml DIAGVERSION [8]SUPPLIER [096] SOFT [007E] VERSION [0300] {17281}
    Identified ECU [VSP]@81 : VSP_v1a5_Flat_20210210T100355.xml DIAGVERSION [4]SUPPLIER [U2F] SOFT [0005] VERSION [0007] {18409}
    Identified ECU [Power steering]@04 : X07_EPS_V3.0_20170811T134219.json DIAGVERSION [4]SUPPLIER [373] SOFT [D201] VERSION [200B] {2603}
    Identified ECU [EPS]@E9 : X07_EPS_V3.0_20170811T134219.json DIAGVERSION [4]SUPPLIER [373] SOFT [D201] VERSION [200B] {2603}
    Identified ECU [SCRCM]@E7 : Inverter_Emotor_SED_SW521_V2_20151110T155153.json DIAGVERSION [4]SUPPLIER [001] SOFT [0204] VERSION [0E30] {5645}
    Identified ECU [BCB]@67 : JB2_0210_8C2_950_V1.0_20200420T130641.xml DIAGVERSION [4]SUPPLIER [JF2] SOFT [0210] VERSION [0931] {10163}
    Identified ECU [PEB]@68 : INV_0220_750_V1.3_20200529T185300.xml DIAGVERSION [20]SUPPLIER [GL4] SOFT [0220] VERSION [7400] {16713}
    Identified ECU [LBC (EV)]@93 : BMS453_00.02.02_00472_00.02.02.ddt_20200218T120557.xml DIAGVERSION [4]SUPPLIER [DA1] SOFT [0472] VERSION [0000] {15365}
    Identified ECU [(H) EVC]@95 : Inverter_Emotor_SED_SW521_V2_20151110T155153.json DIAGVERSION [4]SUPPLIER [001] SOFT [0204] VERSION [0E30] {5645}
    Found ECU [PLC/PLGW] (no relevant ECU file found) :DIAGVERSION [4] SUPPLIER [PAN] SOFT [1405] VERSION [0010]
    Identified ECU [Audio]@13 : R0_13_v2.3_20201210T145616.xml DIAGVERSION [92]SUPPLIER [93E] SOFT [0007] VERSION [0701] {9851}
    Identified ECU [DCM Renault]@77 : TCU_GEN2_3G_DAI_V2.4_20180827T154111.xml DIAGVERSION [8]SUPPLIER [284] SOFT [2100] VERSION [0215] {11423}
    Identified ECU [SCU]@4D : SHIFTER453_03.01.06.ddt_20190726T140324.xml DIAGVERSION [70]SUPPLIER [F34] SOFT [1926] VERSION [1642] {16855}
    Identified ECU [DCM]@78 : SHIFTER453_03.01.06.ddt_20190726T140324.xml DIAGVERSION [70]SUPPLIER [F34] SOFT [1926] VERSION [1642] {16855}
    Es scheint, als würde mir für das UPC-EMM die ECU Datei fehlen. Ich habe auch die anderen alle einmal durchprobiert vom Twingo/Zoe/Clio, aber keine lief vollständig.
    Datenbanken habe ich die 2018, 2019 und 2020 ausprobiert. Sogar eine aus 02/2021.
    Weiß jemand Rat?
    Ich habe mir das EMM Steuergerät versucht anzuschauen. Die Bezeichnung die da drauf steht ist: Renault EMM2-L2 | 505532F02 | 7892024934
    Hallo ronnyflex,
    ich konnte gerade einen Neuen EQ auslesen aber das EMM finde ich nicht, der smart hat auch VOLL LED Scheinwerfer, ich denke da du einen NEUEN EQ hast könnte das wahrscheinlich auch vom smart Center Aktiviert werden, wahrscheinlich benötigen wir da eine Aktuelle Datenbank für das DD4ALL.
    Hm, schade... bei der 2019er DB handelt es sich auch um die "neuste" die so public verfügbar ist, oder?
    Bedeutet: aktuell besteht gar keine Chance da selber etwas frei zu schalten?
    Hi Leute,
    ich habe den Thread soweit durchgelesen. Es gibt hier noch niemanden, der die LED Scheinwerfer in dem neuen MOPF EQ nachgerüstet hat, oder? Habe meinen jetzt letzte Woche bekommen und die Halogen-Scheinwerfer sind...naja.
    Mein Softwarestand "müsste" ziemlich neu sein.
