Thank you Plontine!!
Beiträge von davidoiknine
Thank you!!
Hello,
I’ve installed the new LED facelift headlights on my 2015 453. But I noticed two problems that I’m trying to solve in order to work as original.
1) when low beam headlights are on and blinker is on (one or both), the DRL should completely turn off. Mine stays on.
2) when low beam headlights are off
- if one blinker is on, the DRL is turning off (so this is working on my car)
- if both blinkers are on at the same time (hazard lights) the DRL should turn off (but DRL stays on in my car).
So to sum it up, as soon as the blinkers are on, the DRLs should shut off and I can't apply it in all cases.
(Blinker should be orange in all situations and not orange + white).
I see that you also had this problem but I'm wondering if someone found the solution please?
Thanks for your help.
Hello everyone,
So to sum it up, as soon as the blinkers are on, the DRLs should shut off and I can't apply it in all cases.(Blinker should be orange in all situations and not orange + white).
I’m on SW15 version. Do you think the problem comes from wiring or coding?Thanks for your help.
